RotaryRacer
- Jul 18, 2004
- 1,361
Re: My boat is leaking. Is it normal or excessive?
I wouldn't fill much beyond a few inches in the bilge with any boat especially an I/O boat. You don't want so much water that the motor gets wet at all. You would be better off just floating spending as much time as neccessary to find the leak....if there is one.
One of the concerns mentioned about leaking bellows is that the u-joints and bearings on the shaft between the engine and the outdrive will get corroded due to exposure to water. If this happens and isn't attended to quickly it can lead to additional problems.
I don't know how the engine shaft connects to the outdrive, but if water gets in there, will it do any damage?
