Neversosure
Thread starter- Joined
- Mar 26, 2004
- 12
OK, first thing first.<br />1- put new plugs in, couldn't find the br8hcs-10's like it calls for, so I put in Champions crossovered plugs, what a mistake! Hard starting and a host of other things. The NGK plug #Br8hcs-10 plug is the right one, but no one around here carries it I gotta order them in. The "C" in the model # has to due with a grounding thing, it causes the plug to ground faster then other plugs. So it is running off a lil<br /><br />2-The motor backfires like it has water in one of the cylinders when I first start it. Then I run it at a high idle it will clear up and run great, I run it out in the channel and open it up run's great then when I idle back in to my boat slip it starts popping again. I am leaning towards a coil problem possibility because it is intermittent.???????The motor backfired with the old NGK Br8hcs-10 plugs in it as well.I thought maybe the carbs were outta adjustment, so I checked the mixture screws but the popping continues.<br /><br />3-when I am idling in the boat slip I notice alot of oil coming through the exhaust and floating on the top of the water around my boat, is the oil injection pushing too much oil possibly? (enough oil on top of the water for someone to complain about it)<br /><br /><br />any input would be great!!!
