jim_in_day
Thread starter- Joined
- Aug 29, 2005
- 175
Long story, please read throughly. 76 powerhead with 75 midhousing and lower unit. Parts replaced were head gasket, thermostat and bypass and temp sensor, trigger, stator, coils, fuel pump all new hoses, intake and leaf plate gaskets. work done was rebuilt carbs with new kits (4 times now complete with air and wire probing) reset timing pointer per manual, set carbs to open at tdc per manual, set max advance timing, made certain that all 3 carbs are synced using butterfly amplifier (paper clips with alligator clips on end). Compression #1= 102psi #2 = 112psi #3= 105psi Good spark 1/2 jump <br />Now for the problem It will run fine on muffs starts easily sounds good. Take it out on the water, finally get it to start and run, go fishing and then try to restart it and it will not start, I have been fighting this problem for a year, When it runs, it goes like spit 6000 rpm 30mph (GPS) then it won't start again. What do i need to do besides use it for an anchor?
