Parrot6909
Thread starter- Joined
- Dec 29, 2002
- 69
Bought the motor in August, just needed an idle adjustment I was told.....tried that, still not working right....Here are the details, 1983 70hp Johnson, 501 hours on it....starts great, idles high, shifts hard. When I raise the idle lever, it feels like there is no resistance, if i manually move the throttle lever under the cowling, i can get it down to lower rpms. Also, when putting the boat in forward, i have to go to 3/4 throttle in order to get it to go above idle. Its very tight from the 3/4 to full throttle setting, but the rpms do get up around 5200 at full. When I put the motor in reverse, I can put the throttle all the way back and don't get any higher then Idle rpms which is a pain when docking........Do I need new cables? Maybe a new control box? Don't know where to start...I bought a manual but I don't see much in the way of this problem.....Help!
