My 650 mercury motor Doesnt accelerate in drive
RyeWilkes
My 1968 mercury 650 motor runs smoothly. However, when i have it in gear(forward) it stales out if i try and give it any gas with the throttle. Reverse and neutral both work fine but when i put the motor into gear it can only putt along and eventually stales. (Stales faster if i throttle and give it more gas).
Has anyone had this problem before?
Is it a quick fix?
Do you need any other information?
Thanks,
Ryan
nyx2k
Re: My 650 mercury motor Doesnt accelerate in drive
best guess would be carb jets are gummed up if its a 2stroke.
strip nad clean out jets and carbs
Yesterday
I agree with nyx2k - It sounds like a fuel feed issue. I'd add it may be a weak fuel pump.
brnschoneck
ahhh ha i jsut had this problem things i did ...Rebuilt fuel pumps wich was the problem i beleive they looked pretty bad ?? Took carbs off cleand them , cleaned points , took screw out of fuel tank to vent more , new primer bulb , and new throttle cable as it was old and freyed ...PROBLEM SOLVED .....
