DJ_Allatoona
- Feb 24, 2008
- 187
For several years, I haven't been able to crack the code to getting the more sensitive 12V stuff on my old project Starcraft to behave properly. Stereo head unit, amp, fishfinder, running lights. Most of the time, everything is great, but sometimes they switch off when I throttle up, sometimes I'll get voltage spikes higher than 16V, I've seen 18V on my Garmin, and it will power down with the message, "HIGH VOLTAGE". Sometimes my amp will power on, sometimes it won't. Doesn't seem to be a pattern and it makes me crazy.
I have run new wires, upgraded my fuse block, replaced the switchbox (it needed it), tested the stator (all good), chased all the grounds, replaced connections and terminal ends with heat-shrinks, I even added an aftermarket voltage regulator to my old outboard that wasn't made with one. No help. Everything points to a short somewhere but I could never track it down.
So today I had my battery tested AGAIN, and it's good. It has always tested strong, no bad cells, never suggested replacement, so I considered it good. Cranking is fine, tilt/trim works nice, I thought no battery issue. So I'm telling the guy at Pep Boys, and he had a hunch: -- he tests the battery again, this time on the threaded marine posts, instead of the auto/SAE posts. The test numbers come back garbage! 5 CCA on a 675 CCA battery. Next test: 1 CCA. Message "REPLACE BATTERY". I have always tested my battery on the auto-style posts because it's easier for the clamps, but I use the marine posts for my components. It never occurred to me to do it otherwise.
I got a $6 terminal adapter from Walmart, connected everything back, and like magic, everything works beautifully. For the first time in years, everything comes on and meters 12V or 12.5V as it should. Took a long test ride on the water and zero issues. I almost cried.
So, what does this mean? Is it common on a marine battery that the 3/8 threaded posts are bad, but the auto-style posts are good? Does it mean this battery is on its way out? I have never heard of this type of failure before.
