My 2006 Suzuki DF 115 does not exceed 3000 revolutions
Xino Xano
Hello guys!
I have read that these engines incorporate a water separator that has a ballot that, when it is full of water, does not allow the gasoline to flow through the engine box and the engine can not rise to revolutions ... If that is the case, someone can handle me tell me where is this separator? (if it can be with an image it would be perfect)
I have to tell you that I had a water separator on the boat at the exit of the gasoline tank, and that I had changed the filter for a new one. I also changed the bugs, and even tried to do Operate the engine with a separate tank to rule out the line to catch air ... and the engine still fails ...
I have to say that the engine does not give any signal of error to the counter, everything seems correct ... but when it reaches 3000 revolutions it does not go well and it stretches ...
And since I have read that all the motors incorporate a water separator inside the engine box I wanted to ask if someone can tell me where it is and try if the problem is the famous ballot ... that I can not find!
Many thanks in advance, and good fishing!
Carles
Check to see if the shift switch is sticky.-----If the switch indicates to the the computer it is in neutral the motor simply will not go to full power.
