my 1995 gts sea doo keeps shearing exhaust bolts
heath 4.3
Can i put on the purple exhaust with the 2 mounting holes instead of the white one that came on it and will it help me quit breaking exhaust mounting bolts every time i take it out
sixfigures
Sounds like you have some broken motor mounts , check them closely.
JimS123
Keep what you have. Use a torque wrench when you put (brand) new bolts back in and use blue locktite.
Mark the bolt head positions with a fine tip marker and then check for movement frequently. You break bolts because the other one(s) got loose.
