My 1985 Evinrude 115 is revving insanely high!
hollowch
Been working an this '85 Evinrude 115 VRO (double carburetor) for a few months now. It wasn't started for three years so I've had a few bugs to chase out. I've been able to get the thing started a few times now and run consistently (although it took some finesse to get started). I finally decided it was time to throw it in the water and test it out. I drop it in, trim down, and crank it up... And it starts revving as if I'm holding the throttle all the way to the floor! I'm talking like full blown wide open throttle. I had to shut it down because I was afraid it was going to blow up. What would cause that??
(side note: when I start this thing, it never starts right up. I always have to crank it like 10-20 times, all the while tinkering with the primer bulb and choke switch until I get the mixture just right)
Bosunsmate
Re: My 1985 Evinrude 115 is revving insanely high!
Could be running lean, could be your timing is right out
Have you cleaned the carbs and checked timing?
See where your spark advance is at at start up position, it shouldnt be near full spark advance, it should be near the idle retard stop
hollowch
No I haven't cleaned the carbs. I'm thinking I can rule out the timing because I've been starting it just fine before this started happening suddenly. If it was timing, wouldn't it have been gradual?
Bosunsmate
Clean carbs then.
Nope if a part fails timing can go out straight away
