My 1972 johnson 85 hp
tonyhemm
can anyone tell me witch one is the heat switch that operates the high temp warning horn ,I have engine mod #85esl72r on top of the block there is a 2 wire plug that seems to go into the block then on the bottom of the right head there is a single wire that goes in th the head there this motor is new to me and my first with a thermostat any help would be greatly appreciated
Daviet
Re: My 1972 johnson 85 hp
Welcome to the forum.
The overheat sensor is in the head, #35 on the breakdown below. It should have a single tan wire on it.
:: iShopMarine.com ::
JRegier
Daviet is right. The thermostat in the top of the block automatically gives the motor half choke until it warms up. The other in the head is overheat warning
