My 1972 85HP Chrysler -- Thanks!
turtle1173
Hi all,<br /><br /> I just wanted to thank everyone for all the help with this engine. She is really running great.<br /><br /> Since I got the head re-surfaced, the compression in my bad cylinder (#2), has come all the way back up. I had it out today and checked the compression when I got back to the ramp (#1- 140, #2- 140, #3- 150).<br /><br /> The only thing left to fix is some leaking in the lower unit.<br /><br /> I've also got a lot of vibration at all speeds. I'm guessing that this is because my prop is in poor condition. Lots of bends and dings. One blade has a 1/2" gash out of the end also. Does this sound like my problem?<br /><br />Thanks again everyone!<br /><br />Shane
D
DJ
Guest
Re: My 1972 85HP Chrysler -- Thanks!
Shane,<br /><br />Glad to hear it.<br /><br />Yes, your prop can cause that. It could aslo be causing some of your lower unit troubles.<br /><br />It's not good to run an outboard with a damaged prop.<br /><br />It's sort of like driving a car around with a flat tire.
