MUST HAVE Technical Information for DIYers.
Status
Not open for further replies.
Don S
MUST HAVE Technical Information for DIYers. (< An @ Work Safe Search Version Of ^^^)
If you have NEVER posted in this forum before, please click on How to ask a question link first.
1. How to Ask a Question .... Please Read This Before Posting A Question...
2.
Miscellaneous Mercruiser Information
3. Volvo Penta Information
4. OMC Information
5. Engine ALIGNMENT How to's
6. HOW TO: Troubleshooting your engines starting system
7. HOW TO: Find #1 TDC on the Compression Stroke
8. HOW TO: Testing your boats fuel system.
9. HOW TO: How the Shift Interrupt system works
10. HOW TO: Summerize your Winterized boat
11. HOW TO: Winterize your engine and drive Verified
11A. HOW TO: Winterize your engine. Updated https://forums.iboats.com/threads/winterizing-inboard-and-i-o.770207/
12. Use of muffs to winterize
13. Pressure testing an outdrive
14. MerCruiser Stern Drive leaking oil (1966-current)
15. List of possible causes of low WOT (Wide Open Throttle) rpm.
16. Testing exhaust manifolds for leaks.....
17. Home Made Special Tools
18. How To: Troubleshoot a Points Ignition System
19. How To: Tune-up Your Engine with Points Ignition
20. How Points Ignition Systems Work
21. How Mercruiser Thunderbolt IV and V works.
22. Homebuilt Outdrive Stands
23. U-joint part number....
24. Water in your engine oil
25. Freeze Plugs aren't there to protect from freezing!
26. BoatInfo Manual Link
27. How to test electrical circuits
28. A General Guide To Mercury Marine's Diagnostic Port Engine Scanning Connector Locations Of Many Engine Models...Both I/O & OB...
Keep Scrolling Down, there is still more
Don S
Re: MUST HAVE Technical Information for DIYers.
Terminology so we understand each other.
attachment.php
Here are the specs Don or Bond-O posted. Get a bar 24-36" long of the material you wish to use.
Here is what it looks like when completed.
Status
