Multiple Issues, New to the Boating World
Sde117
I apologize in advance if this is in the wrong area.
I recently picked up a 1985 Starcraft CSS 161 with a Mercruiser 140 in it. I am not new to working on engines or some good old hard work however I come from a motocross/snowmobile background so this type of motor is a bit new for me.
The Motor SN is A464357 and the outdrive is SN: A503049.
Here are the issues that I am having, The motor starts and runs when cold however it has a rather High Idle and then once it warms up it dies. When I look in the carb it was dumping fuel into the motor. I pulled the spark plugs got the fuel out and when I replaced the plugs she fired right back up. She runs if I keep on the throttle but as soon as I get where ever I am going and back off the throttle it will die if I dont throw it into neutral and keep the RPM's higher. I think this is a carb issue however I am not sure. I have done the basics, changed oil, filters, new battery, replaced plugs and the coil. Could this be a timing issue? Last but certainly not least, The prop has a few chips out of it. They are not huge however I am hesitant to continue to use it without the knowledge of if it is impacting internal components.
Again, I apologize for the lack of knowledge. Any tips and help for a new boater would be greatly appreciated.
Ayuh,..... Welcome Aboard,.... Sounds like ya oughta rebuild the carb, 'n make sure the floats are right,....
If motor is Points fired, the points probably oughta be changed,....
As for the prop, if it looks beat, it probably oughta be changed,...
Might run it long enough to see if the pitch is near right,....
welcome aboard.
your carb needs to be disassembled and cleaned if its dumping fuel down the engine
the high idle is because the idle circuit is plugged. dumping fuel is because the float is either shot, or the needle and seat are bad
achris
More fish than mountain goat
... The motor starts and runs when cold however it has a rather High Idle and then once it warms up it dies. ....
That statement concerns me. If I didn't know better, I'd say it was running on a fast idle cam, which means...... Automotive carb has been fitted.... :eek:
Chris........
nola mike
Is there a clear hose near the carb? It should be dry/no fuel in it.
Sde117
Thanks for the help guys, I don't think it is an automotive carb. There is a hose, it's not clear. But I have checked it and it stays dry. The fuel pump seems to be working properly. I will rebuild the carb and check the floats and see if that doesn't help.
