Silvertip
- Sep 22, 2003
- 28,771
Re: multiple coils going bad
Point gap and dwell have a direct relationship. Set the point gap to spec and dwell will also be in the proper range with one big exception. Make darned sure the upper bushing in the distributor is not worn. If it is it will drive you nuts trying to get the engine to run good as the shaft wobbles and causes dwell angle changes. It's obviously best to use a dwell meter but points were set for a gazillion years before dwell meters were available so its not necessary. Heck, a match book cover used to work well. A dwell meter is a valuable tool to detect a worn distributor as dwell will vary considerably when it should be stable regardless of RPM. If you are unsure of the integrity of the wiring, by all means add the ballast resistor and new wiring. There should be another wire coming from the "R" terminal on the starter solenoid. That wire bypasses the ballast resistor during start mode.
