I have a '85 mercruiser 140 with a standard points ignition. Over the years I have had trouble with coils going bad. Years ago I was told to remove the existing resistor wire and replace it with a regular wire and install a coil with an internal resistor. That coil setup worked for a while but eventually went bad too. I probably went thru 3-4 coils over the seasons that it was used. I thought I would try going back to the original setup and installed a new resistor wire, coil, plus a new distributor with new points, condenser, cap & rotor. It ran great for several outings and then the coil crapped out again. It ran very rough all of a sudden and would hardly start and then would not start at all until it cooled down. I switched out the coil with a spare one I had and it started and ran fine. Then I switched back to the original coil and was very hard to start and ran rough. I also put a timimg light on all the spark plug wires and they all showed erratic misses while the engine was running with the old coil. Could anyone give me some ideas of why I keep having coils go bad or what I can troubleshoot for possible causes? Any suggestions or ideas would be greatly appreciated.
