I recently purchased a 16' aluminum boat with 40hp evinrude all from 1991 (12v trolling motor). A home made recharge system was installed which seems to make sense but I hate electricity....mainly because I dont understand it so I would appreciate any comments as to whether it needs addressing or not from a functional and/or saftey stand point.
There were two dual purpose batteries on the boat when I got it. One started the outboard only and the other ran the trolling motor and electronics. The trolling battery was bad and replaced by me with a marine type Walmart brand rated for 750 cranking amps and 109 amp hours at 1amp. The maiden voyage last week showed everything works but with just a half day or so regular bass fishing with the trolling motor I got home to see the battery was worn pretty low. The only tester I have is a cheap green/yellow/red light tester so I cant say for sure how low it was. To make sure I dont lose trolling power during longer days and gain confidence I can run the radio when the Cardinals are playing (which wasnt used on the first trip) I added another deep cycle battery that I plan to wire parallel tonight.
With that picture, my question has to do with the "recharge assistant" that was installed on the lowe covered compartment. The original trolling battery was tucked away under the rear deck so a new terminal was added near the opening to the covered compartment. This recharge terminal consists of two cut pieces for floor board (house floor board with a slight notch out of the rear). The first piece was bolted face to boat with the recessed notch facing out to the battery compartment. The second piece of floor board had two terminal bolts added so the bolt head could be squeezed between the two wood recesses. This piece was screwed with separate screws (dry wall screws) to the first so that the terminal bolts are surrounded by wood on all sides. A washer was added to each terminal bolt to create a metal surround and all trolling motor and accessory wires were connected to these bolts along with the trolling battery feed.
Is this causing any un-necessary draw on the battery when everything is connected and stored?
Are there any issues with using these remote terminals to continue to charge the new batteries?
Now that I have two batteries in parallel should anything be disconnected when not in use?
Thank you for your advise.
