polarisrmk
- May 1, 2010
- 8
I currently have a project going where I am putting an engine with V8 flywheel and bell housing bolt pattern in place of a 3.0 L engine. Obviously the 3.0 bell housing will not fit over the larger flywheel (I already tried). I have a later style bell housing off of a 5.7 V8; however, the bell housing is from an Alpha 1 Gen 1 motor. I discovered tonight that the motor mounts on the MR drive are farther apart (wider) than the motor mounts on the Newer bell housing. My question is: Does the V8 Bell housing from the MR years have the same spacing (width apart from each other) as the 3.0 GM 4 Cyl would, or were the transom mounts different for a V8.
