mounting twin outboards
ralph
I intend to put two 50 hp Johnsons on a 22' flat bottomed fishing skiff. How far apart should they be? What is the proper measurement center to center of the props?
D
DJ
Guest
Re: mounting twin outboards
The flat bottom makes it easy. Just whatever clearance needed to allow the engines to turn all the way-each way.<br /><br />The farther they are apart, the better control you will have at slow speeds-docking etc. Very important on a flat bottom boat.
Bear
What about the alignment in this case? I've heard both a few degrees toe-in and and a few degrees toe-out. I can understand paralell, but... <br />Which is right the way and why? :confused: <br /><br />/Bear
