I have just installed a new deck and want to use pedestal seats instead of the old lounge seats. I am going with the posts that do not require a hole through the deck as I am trying to avoid any holes into the deck. Here is what I was thinking and would like your opinions. Sandwich two 3/4" sealed, 12 x 12, plywood sheets together with PL. Drill the holes for the mount and attach capture nuts to the underside so I can bolt mount down, but not go through the deck.
Why, you ask? I figure this will spread the load out over a wider area and provide plenty of strength no matter what size my passenger is (I'm 215 lbs). However, here is where I need major advice. I was actually thinking of "gluing the plywood sandwich to the deck with PL, or some other substance. Again, I really don't want to punch holes in my "new" deck. I'm not sure this will be sufficient to hold adults while underway. Does anyone have any advice on how to attach such a build without punching through the floor?
