Re: Mounting outboard to transom
I agree with the 4200 over the 5200, if you are only going to do one outboard I would try to find the smaller squeeze tube instead of the cartridge that goes in a caulk gun. As you know the stuff is fairly expensive and once you open it you pretty much need to use it up right away or it starts to cure in the tube or cartridge. You can put it in the fridge to slow down cure time a lot but I think you would be better off getting the small tube that way your not out as much if it does kick off in the tube. Make sure you clean the bolts, holes, inside of holes with q-tip, and surrounding area real well with acetone to assure a good bond to everything. It wont hurt to get some on the threads of the bolts either, it will kind of act like a loctite on the threads.
