Mounting Lowrance Elite 5 HDI on Tracker Pro 165
FCMalik
I have a 2013 Tracker Pro 165 and have recently installed the Lowrance 5 HDI on the transom. I removed the transducer on the fish finder that came with the boat, Lowrance 4 Pro, and put the Elite transducer in the same mount. The unit works good when under 5 MPH but above about 5 MPH it appears there is so much cavitation it makes the unit useless for detecting anything but the bottom. The unit that came with the boat was a much cheaper Lowramce model but did not have this issue. Does anyone have the Elite 5 HDI mounted on a Tracker Pro 165 and if so are you having the same problem. I'm told the unit should read up to around 30-35 MPH, however the hull design is the problem. If you have this united mounted on this boat could you please send me pictures the mounting and details on depth below the hull bottom and transducer angle. My email is FCMalik1@aolcom
Thanks
Chris
