1970Thunderbird
Thread starter- Joined
- Dec 24, 2009
- 111
Hello,
I have a 1978 Mercury 800, 80 hp 4 cylinder engine. I just put it on my boat, a 1970 Thunderbird Seminole, today, but I was hoping someone could help me with regards to the mounting bracket.
The bracket has two large bolts at the top that end in a large, circular disc that presses against the transom. At the bottom, there is a length of metal, kind of like fingers, that has a bolt hole near the bottom. There is a "finger" on either side of the lower leg.
Is there any way to widen the spacing of this bracket? The top bolts aren't too much of a concern, as they don't go through the transom. The bottom bolts, however, are about a half inch off my original bolt holes. Since they're so close, I don't want to drill the transom, as it may crack. It looks as if this is adjustable, as the main bar connecting the two brackets is threaded on both ends and both ends also have a large nut.
Does anyone have experience with adjusting this? Or would I be better off getting some stainless steel plate, countersinking two bolts into it, running those into the bracket, and then drilling two holes in the plate and using my original bolt holes in my transom?
Thanks!
Thanks!
