Mounting Air Cooled 22HP Inboard in a Jon Boat
Re: Mounting Air Cooled 22HP Inboard in a Jon Boat
Rick,
another option would be to get a single output hydro trans like the ones in a zero turn lawn mower. those are hydrostatic, and belt driven, along with bi-directional.
that would give you the ability to run the motor in its sweet spot and vary the drive ratio along its way.
Still going to cost more than a used boat.
minuteman62-64
Don't know if they are still available in libraries or other sources, but, the old "Small Boat Journal" (from back in the '80's) had an article on a DIY setup similar to what you envision. Showed some ways to make your own stuffing box/etc. Only thing I remember from the article was using a couple of strips of bacon as packing material in the DIY stuffing box :)
GA_Boater
Will thick cut bacon work best? What's that smell? :lol:
We still need the OP to come back and tell what he's trying to do.
HT32BSX115
Rick,
Yeah. A hydrostatic drive like that would be sort of like a hydraulic pump driving a hydraulic motor................ infinitely variable but somewhat heavier than a simple sheave/belt system............
You would be able to run the engine at a constant RPM and just use the "hydro-handle" as a speed control!
Sounds like it would be fun to try!! I just LOVE projects! Especially doing 'stuff' that's never been tried!
a lawn mower hydrostat is about 13#, so it istn much weight
fishingman1
Thanks for all the input and ideas. Right now I am just brainstorming and seeing what is possible and/or makes sense. I don't have a set plan yet. However, one of my plans for the future is to build(or rebuild) one of these old boats. I would go with a smaller engine and smaller prop. They are more of a "mud boat" so I would probably need a Steel prop:
Reelfoot Lake Boats Picture 1
They used a small lawn mower engine and they are collectors items now.
Idlespeedonly
Where is small boat lover when you need him?
Me, I would do the pwc conversion. Probably cheaper, and better performance.
I understand why you want to so I hope you have fun with it.
The reelfoot lake boats are somewhat popular, but most are going with jet drives on reelfoot lake now.
JustJason
Why don't you just throw an outboard on it? Most people that try to reinvent the wheel end up with a really crappy wheel.
Ayuh,.... For the effort of the inboard B&S motor,...
I'd just go with the clamp it on the transom B&S Outboard motor,... a Real Mud-motor,...
