MotorGuide wiring problem???
rskinne3
I have a MotorGuide Magnum 752 (foot/pedal controlled) trolling motor.... I inherited our Skeeter bass boat from my father who passed away. (trolling motor is connected to a brand new battery w/ a brand new circuit breaker) Under the foot pedal I had to replace the wiring because of corrosion and cracked wires. I have been using it for the past month but due to a short in an old wire I decided to replace all the wiring in the foot pedal. I rewired the bottom but am still having trouble. At first, when it was ready to go the prop spinned very slowly and came to a stop after 5 secs.. I fealt the ground wire (white) coming from the head unit to the foot pedal and it was very hot. I'm pretty positive that it is just a couple wires I have switched in the wrong places...mainly on the micro switch (when touching a few wires to diff. places on the micro switch the motor will acitivate and work fine, but I'm not pressing the button on top). Obviously, I'm not that great with electrical apps but have added a diagram of what I have set up now. If anyone could give me suggestions about the wiring or any other possible problems I'd really appreciate it. thanks, Rob
Barnacle_Bill
Re: MotorGuide wiring problem???
I can't find a diagram for your motor but that white wire should not be going to ground. Black is ground.
Silvertip
Honorary Supreme Mariner
You don't show the +12V and ground wires coming from the battery. The short black wire you show between the ground terminal and the micro switch is also apparently wrong. You should not have a ground wire on that switch - especially since there is also a non-ground wire on that terminal. You really need a wiring diagram and MotorGuide is the place to get it.
