motorguide shaft bearing assembly
billybass
I have an old Motorguide 3, white, foot controlled trolling motor. The bearing located about halfway down the shaft needs replacing. Where can I find this bearing assembly?
Marc J.
Re: motorguide shaft bearing assembly
It may still be available from Motorguide. I adapted the lower bearing assembly from my old OMC to my Brute 750. It worked out pretty good actually. I inverted and re-used the original metal cuff below the OMC assembly because it tightened up better on the shaft.
NBE
Try one of these. They usually have parts for a lot of different trolling motors. If not, maybe they can steer you to the right place.<br /> web page <br /> web page <br /> web page
trumanlake
did you ever find the part you were looking for?
billybass
No, I haven,t found the bearing assembly yet. I have been in contact via email, with a Ben Hollingsworth who says he may be able to help me by phone , but I haven't called him yet.
trumanlake
i'll look up that bearing an see what i can find in the morning.
b.gagnon
Master Chief Petty Officer
Get to mercury's web site and go to the parts section. Type in your serial number and you should get a parts breakdown and possibly be able to order it right there!
trumanlake
hey billybass, what your looking for is i believe (bearing # AF-005-01 if you need the cup # AF007-010 let me know if you have any problems, i may still have some in my inventory.
