Re: motorguide only works in high speed
We have no idea of its age, model number, 12 volt, 24 volt, or a dual voltage 12 or 24 volt. It would appear that it is an older motor that uses speed coils (essentially wire wound resistors) and one or more of them has burned out leaving you only with high speed which does not require any speed coils in the circuit.
