motorguide ex82sp problems
kentucky22869
i have a motorguide ex82sp 24v that keeps shutting off when under power. on lower speeds it will run for a coupleof minutes but if you turn it up it will only run 15 to 20 secs. i also noticed that outside temp affects it. the hotter it is th sooner it shuts of ican hear it click in the top of the motor when it shuts off any body got any ideas?
Re: motorguide ex82sp problems
Sure -- a circuit breaker is opening due to excess current draw. Remove the prop and check for fish line wrapped around the shaft. Turn the prop by hand. If it seems to turn hard, the bearings have very likely begun to tighten up due to wear or water intrusion. If the prop spins easily, then check electrical connections at the batteries, and at the connectors.
