I have and older reconditioned Motorguide Trolling Motor and the prop stopped turning. To cut to the chase, I an run a jumper wire from the ground wire coming from the battery the the ground terminal that goes down to the motor and the motor will run at one speed (High speed I think). Im fairly sure that means there is an issue in the circuit board.
This tolling motor has been kind of "fickle" for awhile anyway and is probably in need of replacement but money is very tight and my son and I just want to be able to fish for a while longer until we can afford a new one.
If indeed another circuit board would do the trick, where might I find one (new or used)? If there are non available I will just install a small 1 inch jumper on the ground terminals and at least be able to use it on high speed.
Thanks in advance for your time.
Jeff
Jeff
