Motor year?
cookieman
I have a evinrude triumph 65hp and need to find out the year. It is a 3 cylinder and only has one coil with a motorolla power pack on it. I have searched for mmodel number plate and it is gone , I also looked for number in soft plugs and there are none. The flywheel has stamped on it 1969 v-4 , but this is a v-3 so I dont know if they were interchangable or not. Numbers I have found on the motor are 315804 stamped on the head, 313407 stamped on the water jacket, 313227 stamped on the block. I am assuming it is a 1969 but wondered if any of you could help. THANKS
OBJ
Re: Motor year?
Cookieman, I would believe a 73 or 74. There was no 65 horse in 69'. The 65 horse in 68' was a V4. So ya' probably got a 73' or 74'.<br /><br />EDIT: Looking agin...72 to 74 for 65hp. But with three ignition coils. Pre-72', 60hp with one ignition coil. Are ya' sure it's a 65hp.? Do ya' have a title with a model number?
Joe Reeves
Re: Motor year?
The eariler 65hp models were built in 1968, 1972, 1973.<br /><br />In 1968, the 3 cyl model was a 55hp<br />In 1969, the 3 cyl model was a 55hp.<br />In 1971, the 3 cyl model was a 60hp.<br /><br />In 1968 OMC also built a 65hp but it was a V4.<br /><br />1968 was a 3cyl 55hp w/Motorola pack (1 coil). I'm not sure of the powerpack connectors on this model. Hopefully someone else can supply that info.<br /><br />1969 was a 3cyl 55hp w/Motorola pack (1 coil). Had 1 single wire nylon connector and 1 triple wire nylon connector.<br /><br />1970 was a 60hp w/Motorola pack (1 coil). Has 1 single wire connector from pack and three screw connector terminals.<br /><br />1971 was a 60hp w/Motorola pack (1 coil). Has 1 single wire rubber type plug in connector from pack and three screw connector terminals.<br /><br />1972 65hp - Newer type ignition w/3 coils.<br />1973 65hp - Newer type ignition w/3 coils.<br /><br />Bottom line.... It's likely that you do not have a 65hp model. Possibly you can determine exactly what you have by the descriptions above of the powerpack terminals/connectors.
OBJ
Re: Motor year?
Man I have to be missing something here. Joe....my stuff shows the 72' 65hp with three ignition coils. Cookies' shaker only has one. Whud I miss???
Joe Reeves
Re: Motor year?
OBJ.... I was in the process of editing that list and wasn't aware that it had been posted yet. A lot of confusing stuff when we reminisce of those oldies. Just took a moment to straighten it out.
OBJ
Re: Motor year?
Boy ya' sure got that right Joe! Confusing at times.
cookieman
Re: Motor year?
Thanks guys, I will check it and see what I have . Funny the cover says 65hp triumph and you say it may not be a 65 hp. I have to wait till tomorrow for daylight.
