miller92063
- May 29, 2013
- 17
I have a 91celebrity with a 5.7. I can trim the motor down, but not up. Would this just be the button? Maybe a cut or split wire? Anyone else had this issue?
Gonna pull the throttle off and see if somehow maybe a wire got cut in there
Here is the troubleshooting info for the trim, including the wiring diagram.
Assuming you actually have the Alpha I Gen II outdrive. You don't really say what drive you have.
It will work for other drives, but you should know what drive you have as well.
One note, the drive trims up and down, not the motor.
Anyone know a slick way to check the switch?
