motor won't start
wpwrtr
I have a 1990 15hp johnson. I bought it used and it had been sitting for a while. When home I tried to crank it and it was very hard to pull and didn't try to turn over. I replaced the plugs, no help there. The engine looks to be in great condition. Any suggestions?<br /><br />Warren
boatman03
Re: motor won't start
im not a pro but... try and take of the flywheel and look at the coils and see if they are cracked if they are replace them. then look at the points and make sure you have a charge jumping through them.<br /> :cool:
Xcusme
Wpwrtr, Welcome to iboats !!<br />On a 'new to me' motor you will have to do some preliminary checks before you even think about starting the motor. If it's been sitting for God knows how long, you'll want to replace the water pump impeller. They get old and dry and if it comes apart, it may clog the cooling passages. Replace it now and be sure it's new. You'll want to do a compression test on both cylinders, check for spark and look closely at the carb ( for old fuel deposits) and the fuel lines for loose clamps and dryrot, replace as needed. Change the lower unit lube, looking for any metal shavings in the drained lube and any water. Small metal 'glitters' in the old lube are no big deal, metal chunks IS a problem. Water in the old lube can mean bad lower unit seals. <br /><br />Pull the plugs, squirt in some light oil and pull the rope, is it still hard to 'turn over'??<br /><br />If you plan on keeping the motor, by all means buy a service manual, it's money well spent. A link at the bottom of this page can point you to a manual, here at iboats.<br /><br />Post back if you have any additional questions. :D
wpwrtr
when I took the plugs out the flywheel turns easy.
Solittle
There is an excellent FAQ on this on the main page.
Xcusme
Since it spins over easily with the plugs out, that rules out a drive shaft or lower unit binding problem. I'm sure you'll probably find that you were just feeling a motor with good compression. Get a manual, change the water pump impeller, drop it in a test tank and give her a test run.
