motor won't start
Dana Tucker
this is a follow up to my earlier post....I put a new starter on today and tried to start the motor, it's still struggling with plugs in and now the starter won't dis-engage with or without plugs in....I can take a large socket and turn the fly wheel and the starter will dis-engage and I can turn the motor over with the socket on that big nut on top, I can feel it making compression and then it will release the pressure, am I fighting a blown motor or is there just something I can do to fix this, I removed the lower unit and the carb's because I want to change out the water pump and rebuild the carbs. I hope I'm making enough sense here that someone can picture what I'm dealing with, can't afford to take it to a shop so any help will be greatly appreciated......the motor is a 1988 40hp Evinrude
oldboat1
You need to see what the compression is before proceeding. Borrow a screw-in type tester from and auto parts store. With plugs out, crank the engine until the needle stops. Record the result, and move to the next cylinder. (Post results.)
Auxlarry
If you can turn the engine over by hand then the starter should spin it with no problems, especially a new starter. It sounds like dirty wire connections somewhere. Try a jumper cable directly to the post on the starter and the other to ground and see if it spins faster. If it does you need to pull each wire on the starting circuit all the way back to the battery and clean them bright. Put a little dielectric grease on the terminals and tighten everything tight.
F_R
Honorary Supreme Mariner
You cannot afford to take it to a shop, but you could afford a new starter that you didn't need. An experienced outboard mechanic could diagnose the problem in 15 minutes. I could, but i don't do it any more.
Dana Tucker
thanks F_R...that's just what I need some sarcasm, I spent less than a hundred dollars on the starter, the mechanic would have charged me $110 just to take the cover off...if you don't help out anymore why the hell are you on here then? As for all the other guys on here I really appreciate all of you comments. I'm at a cross roads with this stuff, I've replaced everything that I've been told might help, and still it's doing the same thing....I just put a new solenoid on it this morning no help....my problem is the starter stays engaged to the flywheel after it turns over a few times, it tried to start the first few times after I put the solenoid on, but it's back to struggling and sticking, I tried to by pass everything and just jump the starter straight from the battery but that didn't help...is there anyone other than what's his name that might have an idea?
Roberthill
Stater gear is designed to travel up a spline and engage flywheel . When motor starts and you quit cranking the starter gear goes back down . If it doesn't start starter gear will still be engaged to flywheel and as you stated if you turn flywheel it will disengage so I believe that part of it is ok . Not starting is something else . Compression? Fire? Fuel?
oldboat1
If it were mine, I would use regular jumper cables (known good ones), and jump from my car or truck directly to the outboard starter. Pos stud on the starter body, neg to the starter bracket. See if it cranks normally. (Maybe you've already tried that.)
Dana Tucker
thanks for the help....funny thing, I tried putting just a small amount of wd40 on the starter shaft and I'll be damn it worked, thanks for that, now because I changed the fuel system, and rebuilt the carbs I'm having idling issues...it will run as long as I keep the speed up with the lever by the shifter, but as soon as I push that down it will idle down and die....any suggestions?
oldboat1
could be the carb jets aren't completely clean, or idle adjustment is set too low.
oldboat1
Possibly throttle link to cam (#27 in the diagram). Throttle adjustment, not carb.
