Motor won't start?
DevilDoc1
I have a Johnson 90hp 4 stroke (2003) outboard. It won't turn over. I turn the key and the lights in the dash cycle then turn the key to the next position and all you here is the fuel pump. I have tried moving the throttle up and down while turning the key, but nothing. Any help would be helpful.
00000dan
Re: Motor won't start?
i dont know anything about your motor but what i do know is that the guys that do know are going to have to know a little bit more info.<br /><br />is this motor new to you...or have you just started having this problem...if so when did this problem accure.<br /><br />if it not new to you then i know a few things you need to check is compression and spark..but i dont know what psi it needs to be at.<br /><br />alot of this info can be found in a manual...if you dont have one, i would get one.
Goodoleboy
Check battery cables and see if good and tight and no corrosion.<br />Check for lose conection at starter as well. check solonid for good conection.<br /><br />Check key for good and tight connections.<br /><br />Neutral saftey switch may be bad.<br /><br />Good Luck!
DevilDoc1
I got this motor new. I had the boat out over the weekend fishing and pulling a tube. It gave me a heat warning while tubing so I shut it off for about an hour. After it started right up. The next afternoon, nothing. The battery is new and the cable connections are new. I just replaced them about three weeks ago.
Goodoleboy
Idd take it back to the dealer and let him deal with it, And tell him no fixie no dealie.<br /><br />Good Luck!
