Hi, I've got an old 18 foot pontoon with an early 80s 18hp Mercury (serial 7198298).
The motor will only rev up to 3260ish rpm in forward (verified with Tach/hour meter) .
Compression in the two cylinders is 155psi and 160psi.
Idles perfect and does not stumble to its maximum rpm.
It's got the factory prop on it (48-43586-13).
When I put it in reverse I can get the revs up for maybe 2 seconds but then it slows down again.
No water in toons. Doesn't mater if it's 2 adults or 5 adults with fishing gear on board, rpm doesn't really change.
This is my second season with the boat. I don't think the carb has been gone through in 10 years.
Linkages appear to be moving correctly.
Does it seem like the right prop?
Do I need to go through the motor?
Thanks
Allan
Thanks
Allan
