motor wont crank over
dcata
I know this will a little long, but I will try not to be a try to be thorough. I took my tank out cleaned it and put it back in last weekend and when I went to try and start the motor it would just barely crank (batteries fully charged) and after I few tries I seen that my negative cable coming from my engine to the #1 battery was smoking. I went and bought new 4 ga marine wire for the postive cables I ran and 6 ga for the negative side and I made sure I had good connections on the new ends, liquid electrical tape and the heat shrink around all. Now I cant get my motor to even crank over. I have 93 115hp Johnson and I did the test with my test light and I have power to the soleniod, power to the yellow/red wire on the soleniod with key on and power to bottom wire to starter with key on which leads normally to a bad starter. I just by chance had a spare starter and put it on and still the same thing. Any help or thoughts would be highly appreciated. Sorry its so long.
Barnacle_Bill
Re: motor wont crank over
Why did you install a smaller ground wire than the pos? Ground is just as important as the positive and has to carry the same amount of current. Jump the 2 big wires at the solenoid. If it tries to start, replace the solenoid. If it still does nothing then the starter is bad.
dcata
I have jumped the wires and changed the starter. The reason I put the lower wire on is because I was told that the negative wire didnt need to be the same size as the positive. Im far from being a boat mechanic and I do appreciate the inputs.
daselbee
It absolutely needs to be the same size.
And the larger the better. Clean all terminals completely.
Barnacle_Bill
If you jumped the 2 big wires and you are sure all connections are good and battery charged, then you have a starter problem. Take it to your local auto electric shop for testing and rebuild.
