motor will fire to one power pack only
snake91876
Upon further investigation 1982 johnson 115hp will only fire to one powerpack. The other side is dead and gets no fire. What make powerpack fire.
Daviet
Re: motor will fire to one power pack only
Both power packs are the same, switch the and see if the spark moves with the pack.
snake91876
Power pack works on either side but still no spark on left side cylinders
AlTn
Clanton gives reply to Drow which may apply to your problem....page 4...check it out
clanton
Check stator charge coil output, and diode in power pack. Need manual and meter.
