Motor well drain leaking into bildge
BOATINGmatt
I have a 20 ' wellcraft outboard that has two drains in the motor well where sea water enters and then leaves...One of the drain holes has a plastic insert and does not leak into the bildge...The other hole has no insert and after much looking around i have discovered that sea water in migrating through the fiberglass and plywood core in the trasom that is exposed in the drain hole..the water is a steady trickle into the bildge..Where do i get an insert for the drain hole and what is it called..also how do i put in in and seal it in a wet application..the boat is at a mooring and id rather not pull it untill the season ends..(dont have a trailer)..( I can fix better when its on dry dock but what can I do for now)...thank you so much
matt
BOATINGmatt
Re: Motor well drain leaking into bildge
Oh i should also mention that the hole are open, they are just straight thru holes..there are no flappers or valves of any kind
thanks ---Matt
BLU LUNCH
What Wellcraft do you have? Is it a self bailing deck and you don't have any scuppers on it?
BOATINGmatt
its a 1984 20 "...im told its a v20 but honestly im not sure..It does have a deep v but it looks different that most v20's i have seen...I dont really know enough about wellcraft;s to be sure ( i was given the boat by someone who didnt want it anymore))..its a heavy awsome boat tho... there are no scuppers it just two thru holes in the engine well....there is like a thru hull filling in one side but its just wedged in there i can pull it out if i try.....
NYBo
Very bad situation. The transom core is now soaked; rot is the inevitable result if left long enough. That hole needs to be sealed and the transom dried out, pronto. That is going to mean pulling the boat out of the water.
BOATINGmatt
wow..Its a 1984 wellcraft sunhatch 19.6 ft.......thanks i had no idea
BOATINGmatt
how would i seal it?
BOATINGmatt
the boat has only been in the water for a week , , prior it hasnt been in the water for years, ,
NYBo
That would be tough to do properly while the core is wet. To do it properly, assuming no rot (a very big assumption), you would slightly increase the diameter of the hole on the core (without touching the fiberglass) and seal with epoxy. You could then install a through-hull to finish it off.
But right now, you want to stop any more water from entering the hole. Temporary patches over the holes, one both sides, might work, but I really think you're going to need to pull the boat to prevent any more damage from occurring.
