Motor vibrating on land
1989SeaRay
I have a mercruiser 454 that I just finished rebuilding. I fired it up in my driveway and around 1500rpms the whole boat starts to shake. I do not have the drive engaged when this happens. Everything on the motor is basically new including the harmonic balancer. There is also a slight ticking that I haven't been able to track down yet. All of the cylinders are getting spark. Any suggestions on what could make the boat shake?
betayv
Re: Motor vibrating on land
what about you the engine mounts are they new?. I will think about harmonic balancer but you said is new. check the mount.
BaileysBoat
Back to basics, but double check the firing order?
Shrub88
454 is externally balanced.
Did they give you a 427 balancer by mistake?
Was the flywheel changed?
1989SeaRay
It is a 454 8" O.D. Harmonic balancer. The flywheel was not in bad shape so I reused it.
Bt Doctur
double check the firing order by physically tracing each wire from the cap to the plug
Ask me how I know
deves3000gt
I would have to agree with BT i did the same thing in my truck and at about the same rpm's it shook pretty good. and i only had two wires mixed up.
