stealthdrummer
Thread starter- Joined
- Mar 7, 2010
- 95
I just bought a 1990 Hydra sports VS150T and noticed that the motor will not turn as far one direction as the other. It has a dual cable set up. If you disconnect the bracket that is attached to the end of the cables the motor freely turns full lock to lock. You can turn the steering wheel lock to lock and check the cable travel. The only way to get the motor all the way one direction is to flip bracket around. However, when you do this the travel in the opposite direction becomes limited. Flip the bracket around and the problem reverses itself. There is no adjustment in the cables that I can see. Any ideas?
