Motor/trade recommendation
MatD
I have picked up a 1973 16ft fiberglass boat and freshened it up a tad. I also found a 73 18hp Evinrude and rebuilt the carb, fuel pump, ignition, etc, etc, etc. It runs wonderul. A gentlemen I know has a 1973 25hp Evinrude that also runs, but doesn't have as many new parts. His jon boat is only rated for 18hp, so he wants to trade.
Are there any differences between these motors to make the trade not worth it?
Is one easier to work on then the other?
Now that I trust my own motor, will the 7HP increase be worth it?
Thanks everyone in advance!
Motors would be very similar to each other in terms of working on them
lindy46
Motors are about the same when it comes to working on them. If you've done all that work on the 18, you can do it on the 25. That 25 would push the 16' boat a little better, BUT you never know what you're getting into with an unknown motor. You KNOW what you have with the 18. I certainly wouldn't trade even-up if you'll be doing a lot of work on the 25. And be sure to check compression, and check the gearcase for water intrusion.
F_R
The motors are virtually the same---except the 25hp is a souped-up version. Different pistons, cylinder head, carburetor, etc. No you can't mix & match the parts without doing them all. The 25 is faster on the right kind of boat. As for your 16ft fiberglass, it's hard to say what the difference will be. My guess is that it is marginal either way. Why don't you put the 25 on it for a test run? Then make your decision.
