Motor tilt on 66 johnson 20hp
rrkyle
I was wondering what to do about tilting my motor up when im towing the boat.
I have looked all over it and i cant seem to find anything that holds it up. My merc 35 has a little lever that you flip down whenever you want it to stay up.
Also wondering which of the trim holes will offer the best top speed? I dont have any experience without hydraulic trim.
Thanks for any advice.
blimp
Re: Motor tilt on 66 johnson 20hp
generally you should tow with the motor down, it is less stress on the transom. A motor brace is useful here too, it will brace the motor up and away from the transom, relieving the stress. Finding the correct hole for tilt is trial/error. I would use a GPS and see which one is fastest without ventilation or the bow bobbing up and down.
tashasdaddy
buy a transom saver.
rrkyle
I looked at the transom savers at academy im gonna see if i can build somethin like that to help. Anyone done this?
Im just worried about somethin hitting my motor when im towing it. Its only about a foot maybe 16 inches off the ground
rrkyle
So i got in last night was planning on fishing today but my power steering broke so i cant tow my boat to the lake.
My motor is only about 8 inches off the ground when down so until i got a transom saver looks like ill be carryiin the motor in the back of the truck
