motor swapping?
tree96
can you replace an 84 mercruiser 3.0 with alpha 1 drive for a 91 mercruiser 3.0 into the same drive? the mounting bolt pattern is the same not sure if it will match up with everything else. any suggestions?
Re: motor swapping?
Ayuh,... It Should...
