The motor is a johnson 235. It started to surge and when I took the spark plugs off there was water one of the bottom cylinders. The spark plug was coated with white oil and water. I am not sure if the surging is caused by the water in the cylinder or a carb running lean. I am guessing that the head gasket is bad and is lettting water into the cylinder. I checked the compression and it was good so I am wondering if there is a way to test the head gasket. I don't want of just throw money at it and hope that I get lucky.
