motor stuck inn up position
kevin6621
I have a problem with a 1996 Johnson Ocean Runner 150hp. The motor is stuck in the full up position, you can hear the pump running but motor will not come down. Any help would be appreciared.<br />Thanks
rmpenton
Re: motor stuck inn up position
try to get someone to hit the down button while you put preassure on the motor.mine got stuck once and that worked
JB
Hi, Kevin.<br /><br />When an OMC T&T system gets low on fluid it will go up and stay there. Try refilling it.<br /><br />Good luck. :)
