HEY GUYS, I NEED SOME ADVICE FROM SOME EXPERTS ABOUT OUTBOARDS. I BOUGHT MY FAMILY'S OLD SKI BOAT FROM MY PARENTS LAST YEAR. IT HAS BEEN SITTING IN THE GARAGE FOR ABOUT 10 YEARS. THE MOTOR IS A 1977,78 JOHNSON SEAHORSE 175HP OUTBOARD. MY FATHER AND I CHANGED THE OIL, GAS AND PLUGS AND CRANKED THE ENGINE UP. THE OLD GIRL FIRED UP LIKE A CHAMP (EVEN AFTER ALL THESE YEARS). I TOOK HER OUT AND WHEN YOU PUT HER IN GEAR THE ENGINE WOULD CUT OFF. SHE WILL CRANK RIGHT BACK UP AND IDLE AS GOOD AS SHE EVER HAS BUT WHEN YOU PUT HER IN GEAR SHE WILL SHUT OFF. WHEN YOU CAN GET THE MOTOR INTO GEAR SHE WILL STILL RUN ABOUT 55 MPH BUT JUST KEEPS HAVING THE PROBLEM GETTING FROM IDLE INTO GEAR.I TOOK THE BOAT TO THE DEALER AND THEY SAID IT WAS A CARB PROBLEM, SO THEY REBUILT THEM ($400). IT DIDN'T FIX IT. I FINALLY TOOK IT TWO DEALERS TO CHECK THE COMPRESSION AND THEY BOTH AGREED THAT THE MOTOR NEEDED REBUILDING ($2500). STILL NOT TRUSTING THEM I BOUGHT A COMPRESSION TESTED AND CHECKED THE COMPRESSION MYSELF. I HAVE 5 CYLINDERS AT 90-95% AND ONE AT ABOUT 40% (I BELIEVE IT IS NUMBER ONE CYLINDER--BOTTOM RIGHT HAND SIDE). IS THIS THE REASON THE ENGINE WILL NOT GO INTO GEAR AND WHAT CAN I DO TO FIX IT? DO I NEED TO TOTALLY REBUILD THE ENGINE OR IS THERE A WAY TO SALVAGE COMPRESSION IN THIS CYLINDER? I HAVE TALKED TO DEALERS ALL OVER FLORIDA, SOME SAY I NEED TO JUST SCRAP THE ENGINE AND PUT A NEW ONE ON ($1500-$6000), SOME SAY THAT THE SEAHORSE IS A GOOD ENGINE I JUST NEED TO PUT NEW RINGS IN IT ($2000), AND OTHERS SAY I NEED TO REPLACE THE POWERHEAD ($2500-3000). WHAT DO I DO. IS MY ENGINE THAT RUNS THAT HARD AND EXPENSIVE TO FIX. CAN I FIX THIS PROBLEM MYSELF AND WHAT TYPE OF MANUALS SHOULD I USE? I WOULD GREATLY APPRECIATE SOME ADVICE FROM EXPERTS WHO ARE NOT WANTING A CHECK FROM ME.
