Fishingman99
Thread starter- Joined
- Jun 14, 2003
- 2
Hi, I have a 1992, Johnson 60 Hp that as soon as I put it in gear it stalls. The compression is #1-115, #2-114, and #3-115. The engine seems to idle fine but it appears the #3 cyclinder is not contributing. When I pull the #1 wire the motor stops right away. The same thing happens when I pull the #2 plug wire. But when I pull the #3 wire the motor keeps idling without change. Swapped the plug, wire and coil pack between the #2 and #3 cylinder without any change. My guess is I'm looking at a fuel problem but not sure what kind of fuel problem might cause this symtom. Any suggestions or ideas would be appreciated!
