Re: Motor slowly loses power
like fireman said first, it sure sounds electrical to me. When you checked for spark, you tested when it was running lousy right, not when it was running well? (idling well with no load)...<br /><br />Also getting a shock isn't the best way to test. A spark tester is better, but I like a timing light to check spark and timing while running the best. Nice that it can be done while motor is on the boat and acting up (which is when spark might be intermittent).<br /><br />Having said this, it could be a dirty/clogged carb or other fuel problem... But when's the last time you serviced the points or had a peak at the coils?<br /><br />good luck<br /><br />Brent
