Duckhunter08
Thread starter- Joined
- May 17, 2010
- 13
my 1990 150 black max was running rough when i first bought it. it wouldnt start without starting fluid, very bad deal. I did what is called "De-carbing" the motor by fogging out the carbs with seafoam deep creep and it was a night and day difference. when the motor was running full tilt the speedometer read 53 mph my boat is a 1990 astro quickfire fish and ski 18 ft. Since then the speedometer has quit but gps claims top speed is 40 mph. Not sure if gauge on boat read wrong or if it has lost speed. the main question I have is that is runs okay but will not idle well i have to throttle advance it everytime and acclerate fast so it doesnt have time to die. idles fine out of water but backpressure is enought to kill it in the water. When I remove plug wires i cant tell any noticeable difference in how the motor sounds. boat hits plane within three seconds so there doesnt seem to be much power loss. there are two phillips screws above the top carb im not sure if i can adjust it to idle a little higher or how to test to make sure all cylinders are firing. im thinking about putting a car spark plug in each wire to see it arc since the marine ones dont have the leg on the end to arc. right now I am running 87 octane with sta-bil ethanol treatment for fuel. oil injection system has been removed. 50:1 ration pre mix
no leaks in fuel lines it will hold prime for days on end. any input is appreciated, thanks
