Motor Rises in Reverse - 1997 Evinrude 225hp
markw01915
I just purchased a rebuilt tilt assembly as my old one wouldn't hold the motor up and also rose up in reverse.
My marina installed the rebuilt tilt assembly and when they were moving the boat to the slip informed me that in reverse the outboard was still rising up.
I had them pull the boat out of the water.
I received the rebuilt unit dry. so I am sure like car brakes there is a specific process to fill, bleed, and get he air out.
My marina repair shop is Yamaha and Mercruiser focused. Not that familiar with Evinrude, so I am not 100% sure they properly bled the hydraulics.
My questions:
1. Can anyone share what the proper bleeding process would be for that tilt assembly?
2. Is there a way to test whether it is working properly (not rising in reverse) before putting it back in the water?
Thank you all in advance for your help.
Mark
Pro line 231 Walk around
jakedaawg
Raise and lower the unit several times to bleed. Keep it full as you do so. If you can't pull it up it will probably be fine. Make sure manual override screw is in.
markw01915
Thank you both for your insight. Boat has been pulled and the service shop at the marina will try to solve the problem today.
Best regards and Happy Father's day !
