Re: Motor ran great all summer, then just stopped dead--2003 Johnson 50
I checked all the connections at the amphenol connector, the back of the key switch in the control, the deutch connectors at the control and from the control cable inside the motor. Also checked all the connections at the terminal block and re-spliced the yellow wire mentioned above (soldered it).
Everything seems OK, no loose connections, wires all in good shape. As mentioned, everything is brand new and installed less than a year ago - control, control cable, system check/tach. Leads me to suspect something inside the motor. I didn't really expect any different result after not finding anything, but attempted starting again and it didn't start.
